New Monitor help
TheJedi
I'm looking for a 1440p 240hz 27" Monitor for Competitive games. I'm currently looking at Samsung G7 and Alienware AW2721D Anyone else have any other suggestions?
I don't care about ergonomics because I'm gonna mount it.
I just want performance.
Thanks
System
CPU: Ryzen 5 3600
Case: Phanteks eclipse P400A
Motherboard: MSI B550 Gaming Carbon WiFi
GPU: MSI RTX 3060 TI Gaming X Trio
RAM: 16GB XPG D60G CL16 3200MHZ
PSU: Sharkoon SilentStorm Cool Zero 650W
Storage: Crucial P2 1TB
Thanks
whats your budget, preferred size, and preferred hertz?
I have an unlimited budget tbh, less than £600 would be preferred but I could go higher if I deem it worth the extra.
240hz is my preferred refresh rate.
27 inch is my preferred size.
System
CPU: Ryzen 5 3600
Thanks
the Asus PG279QM is the best 27" 240hz monitor
Die-hard competitive or do you want an overall versatile monitor also fit for other games?
If just for competitive playing, the Viewsonic XG2431 will offer everything higher-end options will in terms of input lag, response times, motion clarity, backlight strobing, etc.
If the Viewsonic isn't available, the Asus VG259QM is the next best option:
If you want a more versatile monitor with better picture quality, higher resolution, better color accuracity, etc. the Asus PG279QM is as good as it gets for 27" 1440p 240Hz.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
