Search In
  • More options...
Find results that contain...
Find results in...
ubuntu running lag and slow on my pc
bidenkim
 Share
it can't play youtube smoothly while using web browser with several web pages
ubuntu sucks
it is a bad operating systems.
my pc specs:
celeron n3050
8gb ddr3
I have a laptop with n3060 and less ram. Hardware accelerated video doesnt work on linux, ubuntu is also not light on resources, your only option is to use h264ify and use firefox (last I checked it had a half working hardware acceleration for H264 videos), I can also recommend linux mint instead of ubuntu as it is significantly lighter on CPU resources.
mY s YsTeM iS Not pErfoRmInG aS gOOd As I sAW oN yOuTuBe. WhA t IS a GoOd FaN CuRVe??!!? wHat aRe tEh GoOd OvERclok SeTTinGS FoR My CaRd??
 HoW CaN I foRcE my GpU to uSe 1o0%? BuT WiLL i HaVE Bo0tllEnEcKs? RyZEN dOeS NoT peRfORm BetTer wItH HiGhER sPEED RaM!!dId i WiN teH SiLiCON LotTerrYyOu ShoUlD dEsHrOuD uR GPUmy SYstEm iS UNDerPerforMiNg iN WarzONEcan mY Pc Run WiNdOwS 11 ?woUld BaKInG MY GRaPHics card fIX it?
 MultimETeR TeSTiNG!! aMd'S GpU DrIvErS aRe as goOD aS NviDia's YOU SHoUlD oVERCloCk yOUR ramS To 5000C18
16 hours ago, HQuan said:
Well, Ubuntu require more hardware than Windows.
Shut.
I think you should unistall the Ubuntu and install Windows 7 or 8 on that machine. It can run Windows 10 but I think it will not very stable.
Do you have any idea what word stable means? or if that machine can actually run windows7/8? because you cant. No chipset and gpu drivers are available for that platform on anything earlier than W10. I'll repeat, dont give advice on things you have no clue about.
As others have said, hardware acceleration isn't supported on Linux. You can enable it (Firefox only):
https://discourse.ubuntu.com/t/enabling-accelerated-video-decoding-in-firefox-on-ubuntu-21-04/22081
I don't know how well it works though.
You should keep in mind that Linux is not Windows, if you expect it to "just work" you're gonna be disappointed.
==tread locked==
company x or y sucks is not allowed
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 2.0: R7 2700 @4.0ghz, B450m Steel Legends, H105, 4x8gb Geil EVO 2866, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review      Buy my old RX 580
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
Guest
 Share
