Ryzen Master Crashes on dual monitor setup
Go to solution Solved by jj9987,
Reinstall it?
I'm running dual monitors and I'm not having any issues with Ryzen Master.
Hi, Yesterday I just installed  my second monitor (both via Display Port) and today, when I started my PC and run Ryzen Master, noticed that it opened in the second monitor and inmidiately crashes.
Im not able to change the display it starts in (even with win + shift + right or with the display port disconected from the second display)
Is there a way to fix it?
I looked in the internet and 2 years ago some people had the same problem and kind of fixed it without moving to the secondary display, my problem is that it only starts in that display.
Thank you in advance
https://linustechtips.com/topic/1401964-ryzen-master-crashes-on-dual-monitor-setup/
Reinstall it?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
  • 11 months later...
Cause found!
After years of suffering with this issue I have finally found a fix. It's ASUS Sonic Studio / Sonic Radar that is causing this. It injects a NahimicOSD.dll file into the process for some reason and this specifically causes it to crash when not opening on your primary display.
As I had no use for Sonic Radar in my case I uninstalled it and the issue went away (no restart necessary). Opens and closes without a problem on any monitor now.
Hope this helps!
