Color correction on old Slide Scans
5 hours ago, FloRolf said:You wanna do 50 more?
Hey hey, you did all the legwork by providing a colorized version, I just edited based upon that!
5 hours ago, FloRolf said:I honestly hate Photo Editing because i really don't know how all that layering stuff actually works but it seems to produce good results so i might have to look into it!
Smudge removale seems easy though, i guess i do that first right, so that it goes through all the greyscale layers etc?
Doing the clean up (i.e. artifact/smudges) is best to do at first, that way everytime you'd copy the layer, that stuff transfers with it (plus, any small mishaps with the removal of that stuff is 'covered up' by some of the edits made later)
5 hours ago, FloRolf said:Do you mind sending me the full size version of your edit? I think i'll use that!
I've attached the .xcf (GIMP) file below. I have removed some less important layers, but kept the most important ones (and gave them hopefully useful names).
Some layers have a different mode and opacity, to change their effect on below layers and generally change the effect of that effect.
