High temps MSI MAG Coreliquid 240R
Solved by GuiltySpark_,
That case specifies 170mm max CPU cooler height and Noctua's gigantic NH-D15 is officially listed as 165mm with fan's installed. So height clearance is likely not going to be an issue.
That being said, the NH-D15 is likely unnecessary for your 10600k and something like their NH-U12S would fit the bill just fine. There are many options for you to choose from and you can reference something like this to help better make a decision.
