Search In
  • More options...
Find results that contain...
Find results in...
USB 3.1 - USB Hubs don't work?
TheNaitsyrk
 Share
Hello.
I needed to hook up 4-way USB extension to my PC. Specific scenario.
I plugged it into USB 3.1 (red port).
I've got X299 EVGA Dark. Tried to look for drivers for it, but could find nothing of the sort.
I am wondering why it's not working? If I plug in individual things it's happy and fine.
Main PC:
CPU: Intel 10980XE 5.2Ghz 1.33V HT OFF or 5.1Ghz HT ON Same Voltage - Cooled by
Optimus Signature V2 Copper Nickel CPU Block.
Motherboard: X299 EVGA Dark.
RAM: Patriot Viper 4x8GB DDR4 4400Mhz C19 Kit OC 4000Mhz CL14.
GPU: ASUS RTX 3090 Strix (KPN 1000W BIOS) With EKWB Quantum RGB Block and RGB Active backplate from EK.
Case: My own case fabricated out of aluminium and wood.
Storage: 2x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x 1TB Samsung 981a NVMe, 1x External 2TB Seagate Barracuda (Backup).
WiFi: AX210 WiFi 6 Tri-Band card module.
PSU: Corsair AX1600i with custom black and red cables.
Display: Samsung Oddysey G9 240Hz Ver. 5120x1440 with G-Sync and Freesync Premium Pro 1008 Firmware Ver, and 1x Electriq USB C 1080p 15'8 inch IPS portable display for temperature and stats.
Fan Controllers: 5x AquaComputer Octo with 5 temperature sensors.
Cooling: Two Custom Loops:
1st Loop: 4x 480mm XE CoolStream radiators and 1x 240mm XE Coolstream radiator with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, red coolant.
2nd Loop: 4x 480mm XE CoolStream radiators and 1x 240mm XE Coolstream radiator with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant.
Total: 4x pumps and 10x radiators.
Keyboard: Razer BlackWidow V3 RGB - Green switches.
Sound: Logitech Z680 5.1 THX Certified 505W Speakers.
Mouse: Razer Basilisk Ultimate Wireless with charging dock.
Piano: Yamaha P155.
Phone: Oppo Find X2 Pro.
Camera: Logitech C922.
VR: Oculus Rift S.
External SSD: 256GB Overclocking OS.
Laptop: Lenovo Legion 7
R7 5800H, RTX 3080 165W 16GB GDDR6 +170 core +1000 memory, 2x32GB DDR4 3200Mhz CL22, 165Hz display 2560x1600 HDR 500nit G-SYNC + FreeSync, 2x 1TB Crucial P5 NVMe SSDs, AX200 WiFi, with Tobii facial locking security camera, and 3x External 240GB SSDs, and 2x Electriq 1080P IPS USB-C 15'8 inch portable displays.
A USB hub shouldn't need drivers. Is it a powered hub? If so, did you connect it to a power supply?
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 11 Pro
Pluto: Intel Core i7-2600, 24GB 1333MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 700W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i7-2600K, 16GB 1600MHz DDR3, ASUS P8Z68-V, 1GB ZOTAC Nvidia GeForce GTX 550 Ti, 240GB Kingston V300, 3TB HDD + 3x2TB HDD, 750W Dell PSU, Dell XPS 630i case, Windows Server 2019
Mid 2011 27" iMac (general use Mac): Intel Core i5-2400, 32GB 1333MHz DDR3, Z68 Logic Board, 1GB AMD Radeon HD 6970M, 500GB Crucial MX500, 2TB WD Blue, macOS High Sierra
It's not the hub which needs drivers but the USB 3.1. if I try USB 3.0 everything works.
Very petty issue but is annoying haha.
Main PC:
Piano: Yamaha P155.
VR: Oculus Rift S.
 Share
