Search In
  • More options...
Find results that contain...
Find results in...
Chassis Fans Not Working
 Share
Hey guys! My first post, hope I do this correctly.
Building my first pc, everything going smoothly, everything turns on and posts, my Corsair AIO radiator fans work perfectly, yet I noticed the 3 chassis fans included with the case don’t spin/light up.
They jitter once when I turn the system on then don’t move.
At first I thought it was the fan curve, so I adjusted accordingly. Nothing.
Then I changed the Fan headers they were plugged into. Nothing.
I even plugged them into the Corsair Commander Pro. Nothing.
So I decided to plug my fans into my other pc, so it had a completely different motherboard and psu. Still nothing.
I troubleshooted for a bit longer between both the PCs, when I noticed that the actual center of every chassis fan was hot to the touch. This seems bad. I thought maybe not enough power to spin?
The motherboard fan headers were rated at 1amp and the fans are only 0.2 so it’s not power.
What am I doing wrong?
Aerocool Shard RGB case + 3 included 120mm fans
Tuff B550M-E Motherboard
Ryzen 5600g
Corsair h100i elite
Asia Dual RTX2060
Corsair CX650M Bronze
2xNVME ssd
post a pic of the fan headers?
(The fan connector, not the mobo connector)
...  what model fan is it?  That looks more like an RGB connector than a fan header
After checking, I don't think those are normal fan headers, and you need a special hub to control them, did it come with the case?
If the fan does not when you set it at full speed it might be doa 4 pin fan connection is PWM connection normal connection
 Share
Newegg
