Best High-CFM fans NO RGB!
Solved by GuiltySpark_,
$15 isn't going to get you a well known high end, high CFM fan so what you're looking for are budget options.
You could just throw a bunch of Arctic P12's (or F12's if you can find them) at it and be done with it. The airflow is absolutely "good enough" especially if you're sticking to that budget per fan.
bern420 ·
Posted in Graphics Cards0 -
9
5
2
2
Ezra Lewis ·
Posted in New Builds and Planning2 -
13
play_circle_filled
Latest From Linus Tech Tips:
The Stealthiest Tech Upgrade - AMD $5000 Ultimate Tech Upgrade
