Search In
  • More options...
Find results that contain...
Find results in...
Making a Build. Need A Review
Nickel996
 Share
Budget (including currency):  $1500
Country:  USA
Games, programs or workloads that it will be used for:  Games, 3D Model (Inventor), Light coding
Other details
Designing a PC for a friend this is my initial suggestion please add your comments
https://pcpartpicker.com/list/PmBzmk
3D models can get quite large, depending on the detail. 2.5TB total storage should be fine, but I'd consider tossing a slightly larger HDD in there, personally. Depends on their work/how many videos they store.
I would consider going to 12600K. It's typically around the same price, and performs much better than anything else at the same price range. Here's an example build:
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($299.99 @ Newegg)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler  ($51.43 @ Amazon)
Motherboard: Gigabyte Z690 GAMING X DDR4 ATX LGA1700 Motherboard  ($229.99 @ Newegg)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($104.99 @ Amazon)
Storage: PNY CS2130 2 TB M.2-2280 NVME Solid State Drive  ($184.99 @ Amazon)
Video Card: EVGA GeForce RTX 3060 12 GB XC BLACK GAMING Video Card  ($450.00)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($69.98 @ Amazon)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($83.19 @ Amazon)
Total: $1474.56
Generated by PCPartPicker 2021-12-08 00:27 EST-0500
Went with 32GB cause I find inventor uses quick a bit of ram. Less overkill cooler, but you can go with the Noctua one you selected if you like it. Went with a 2TB Nvme drive instead, mainly for similar file management.
i doubt you can find 3060 under 800 usd now
CPU: Intel Core i7-11700F 2.5 GHz 8-Core Processor  ($309.99 @ Newegg)
CPU Cooler: Deepcool GAMMAXX 400 Blue 74.34 CFM CPU Cooler  ($18.98 @ Amazon)
Motherboard: Asus PRIME B560-PLUS ATX LGA1200 Motherboard  ($119.99 @ Amazon)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($51.97 @ Amazon)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($42.99 @ Amazon)
Video Card: EVGA GeForce RTX 3060 12 GB XC GAMING Video Card  ($874.90 @ Amazon)
Case: Fractal Design Focus G ATX Mid Tower Case  ($49.98 @ Newegg)
Power Supply: SeaSonic FOCUS Plus Platinum 750 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($74.99 @ Newegg)
Total: $1543.79
Generated by PCPartPicker 2021-12-08 03:08 EST-0500
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  ($414.88 @ Newegg)
CPU Cooler: Thermalright TA140 EX 95.5 CFM CPU Cooler  ($44.72 @ Amazon)
Motherboard: Gigabyte Z690 UD DDR4 ATX LGA1700 Motherboard  ($199.99 @ B&H)
Memory: Neo Forza FAYE 32 GB (2 x 16 GB) DDR4-4400 CL19 Memory  ($129.99 @ Newegg Sellers)
Storage: SK hynix Gold P31 500 GB M.2-2280 NVME Solid State Drive  ($64.98 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($46.99 @ Amazon)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: SeaSonic FOCUS GX 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Newegg)
Total: $1501.53
Generated by PCPartPicker 2021-12-08 07:39 EST-0500
 Share
