ASUS GT-AX11000 firmware update problems.
Solved by LAwLz,
This is perfectly fine. Nothing to worry about.
You will always get a certificate error when browsing to an IP using HTTPS like you are right now.
You used to browse with unencrypted HTTP, which is why your router now suggested you upgrade to HTTPS.
EzioWar ·
Posted in Operating Systems1 -
4
Lonewolf6869 ·
Posted in Power Supplies3 -
EzioWar ·
Posted in CPUs, Motherboards, and Memory1 -
3
WallacEngineering ·
Posted in PC Gaming0 -
Astrophel ·
Posted in Storage Devices1 -
3
