What is some good silent fans?
MingLee420
Planning to get a small case for my pc the o11 air mini and i checked that it can support all my parts but not sure what fans to get
i only have a a12x15 120mm and would put it in the rear, i only need either 3 120mm or 2 140mm for top and bottom and 2 120mmm for the front side but id say i don't need it, I want silent but good fans with a fan controller
and if it's rgb id def like a rgb splitter
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
System specs? What are your priorities?
Where are you shopping / located? Budget?
From my experience of having gone through fans from several different brands, I haven't had any issues with Noctua or Antec case fans. My current case fans are from them, the Noctua is about 3 years old and the rest are Antec, two of which I've been running since 2013. No bearing noise, rattle, issues spinning, etc.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
Specs are in my profle, silent and good airflow, australia,  120 dollars budget
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
Are you not satisfied with your current fans? Are they too noisy?
I only have 1 fan that can fit the other 3 is 200mm fans
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
I personally would recommend the bequiet! Silent wing 3, good airflow and almost inaudible at max speed. And if you want RGB get the light wings by bequiet!, assuming they are in stock.
https://pcpartpicker.com/product/WrvZxr/be-quiet-bl066-505-cfm-120mm-fan-bl066
https://pcpartpicker.com/product/KyZ9TW/be-quiet-light-wings-pwm-high-speed-523-cfm-120-mm-fans-3-pack-bl077
a company known as bequiet is well known for making good fans and living up to their specs, the newest models (light wings) have a few reviews out
seems like everything over here bequiet is out of stock of every fan aprt from pure wings 2 and shadow wings 2 and light wings seem to expensive for only 3 fans, i might go with arctic fans  4 p14 fans are 68 aud and 2 12p's which are 30  and adds up to 115 with shipping apart from arctic is there any others?
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
Are the 200mm fans already installed?
It isn't necessarily helpful to fill every available fan mount.
the 200mm fans are in my case big case rn i havent got the stuff yet but i just want really good airflow as seeing gamersnexus review the gpu gets like 7 degrees higher in the out of the box 011 air mini than the cooler master h500 which is what i have
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
If you don't mind the thicker width at 29mm, the NB-eLoop B14-PS PWM for bottom intake is hard to go wrong with: https://au.pcpartpicker.com/product/kpYLrH/noiseblocker-nb-eloop-b14-ps-black-edition-839-cfm-140mm-fan-itr-b14-ps-bl
Along with the stock case fans and the NF-A12x15 for top exhaust, it should be plenty for cooling and fairly quiet with the correct fan curves.
NF-A14's are also great if you wanted matching fans or a standard 25mm thickness. https://au.pcpartpicker.com/product/dwR48d/noctua-case-fan-nfa14pwm
Why are you looking for a fan controller? Have you tried using software like FanControl?
yeah, I remember the one "disbenefit" of bequiet fans being the cost, some of which are close to $30/fan
tbh i might just wait a few weeks and get corsair ml or ll fans kinda wanna get rgb for this build as i think it will look good and they're not bad for airflow and noise but it's either ml or ll
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
alr, I personally am planning on getting the bequiet ones and some phanteks frames for rgb, but I can't recommend it due to the cost ($40/fan including frames)
