Pcie slot clip broken/doesnt work
Solved by Windows7ge,
- Realistically no, technically yes. It depends on how it's actually broken and if you can source the replacement part which isn't incredibility likely unfortunately.
- If it's screwed in I wouldn't sweat it. Might want to avoid laying the chassis down on the side oppose the motherboard though.
- Unless you have a frequent tendency to move your computer around a lot it shouldn't but if somehow it did issues could range from no POST to potentially hardware damage if the two wrong pins were to ever short together.
- That's a tricky subject that you might be better off testing to see if any of your applications would see an impact. Older generation GPUs never needed a full x16 slot but there's been some speculation with new cards that it may be necessary in certain applications. You're best to test it.
