How do i connect two monitors ?
Solved by 0fps,
9 hours ago, --SID-- said:So both monitor and TV have a HDMI connector. RX550 has DVI, HDMI and Displayport. The TV you connect with a HDMI>HDMI cable, the monitor you connect with a Displayport>HDMI cable.
okay thanks ill try that and then let you guys know
Blawe17 ·
Posted in Troubleshooting0 -
Ronbaow ·
zoneeye ·
Posted in Troubleshooting2 -
leclod ·
Posted in Operating Systems3 -
PatRed ·
Posted in New Builds and Planning6 -
1
2
StormBreakes ·
Posted in Build Logs1 -
4
1
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
