Search In
  • More options...
Find results that contain...
Find results in...
My XFX Radeon RX 6600 XT isnt compatible motherboard miq17or
RubenMarques
 Share
I can't install my grafic card because "atx_sys" is in the way. Can u guys help me?
the agony that pre-builts give...
Only things i can think get aftermarket cooler for the GPU, or use a Dremel-tool.
Or remove the plug, but i'm guessing its need for correct functioning.
If you're really handy with a soldering iron, you could take off the physical plug of the motherboard, then solder some wires.
And have another plug on those wires to re-connect it again.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
 Share
