Could generic rgb fans work for a pc case?
Tashipirin
I'm planning on buying some fans for my AeroCool Cylon RGB case, it has space for 2 120mm fans in the front, a 120mm fan above the case and 120mm rear fan
If your motherboard has enough fan and RGB headers you should have no problems, otherwise you'll need a hub.
Not sure how much the fans will cost but you may be able to find a better case for a similar price, this case has no airflow and probably won't get much better with extra fans
