Search In
  • More options...
Find results that contain...
Find results in...
High CPU temps (around 95 C only chrome).... No overclocking, everything default. Please help
ishavgupta
 Share
Go to solution Solved by rickeo,
Chrome is using 78% CPU usage, that's going to produce heat. Something in one of your tabs or your extensions is causing a ton of usage for Chrome. That's where you need to start.
The real problem here isn't the temperature, that's normal. However if you feel that your PC is "idle" and not doing anything, that couldn't be further from the truth and you may want to figure out what its doing.
I used to sense some sort of "burning smell" from my laptop. I thought this was due to some burning of dust/wood as it is kept on a wooden table. But today I checked the temps and these are the results. Are these "okay" and "safe". Its more than 1-2 years since I am getting this smell I have also replaced my thermal sensor as it got broken.
image.png.2444e20e894c877c922e10f5a2741693.png     image.png.99bdf858c35c5e2551a199958602ecd3.png
Task manager: (Two chrome tabs (towardsdatascience.com) are using most of the cpu resources ) ofc they vary from 40- 80%
Normal for that type of Laptop CPU.
PSU Tier List Thread | Community Standards | Fan Control Software
"White Ice"
Ryzen 9 5900x | Asus Crosshair VIII Hero (Wi-Fi) | EVGA RTX 2080ti | Ballistix 32gb 16-18-18-36 3600mhz | Custom Water Loop | 1tb Samsung 970 Evo
2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX850 PSU | 3x Corsair LL140 | 3x Corsair LL120
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 32gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Phanteks Enthoo Evolv |  Elgato HD60 Pro | Avermedia Live Gamer Duo | Avermedia 4k GC573 Capture Card
Yeah. That CPU ist fine up to about 100°C and that often happens with laptops.... ( T Junction is at 100°C and then it will throttle, so just above that will become "unsafe")
Yoou could try redoing thermal paste...but there is guarantee that that will help. It could though.
However, do not expect massive gains. there are a few degress in a new application of paste.
31 minutes ago, ishavgupta said:
|| AMD Ryzen 5 3600 @4.2hz 1.15V || Noctua NH-D9L || 16GB (2×8GB) Aegis 3000Mhz CL16 ||
|| EVGA RTX 3060 XC 12GB || MSI B450i Gaming PLUS MAX Wifi
  || Kingston NV1 2TB m.2 ||  Cooler Master G450M || Intertech IM 1 ||
|| Sennheiser PC  360 G4ME || AOC 24G2U || SteelSeries 6GV2 || Logitech G403 Wireless || XPS 13 2in1 7390 ||
Elite 110 build log (update:05/15/2018)
Cleaning the cooling vents on a notebook can help so much.
If its over 2 years old replacing thermal paste can help, but no guarantee.
Personally i would expect a bit less CPU usage with Chrome (but i dont expect more then 1 windows with max 8 tabs open).
Check which plugins are installed. Maybe even open the Chrome task-manager to see whats eating it all.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
Here even with 4 windows with ~5ish tabs each Chrome doesn't use that much RAM and barely any CPU, so you must be just be on one/more sites that use tons of ressources.
F@H
Desktop: i7-5960X 4.4GHz, Noctua NH-D14, ASUS Rampage V, 32GB, RTX3080, 2TB SX8200Pro, 2x16TB Ironwolf RAID0, Corsair HX1200, Thermaltake Overseer RX1, Samsung 4K curved 49" TV, 23" secondary, Mountain Everest Max
Dell XPS 2 in 1 2019, 32GB, 1TB, 4K
GPD Win 2
Yes that, or have a miner plugin installed, eating valuable resources. 😉
Altho GPU to low for that tbh.
5800x/3090
Yeah Thank you all. Also as I have already stated (It was hidden between the pictures) that yes only one site was using most of the resources (i.e. towardsdatascience.com)
 Share
