Search In
  • More options...
Find results that contain...
Find results in...
What is a good Speed for a NAS
Plermpel
 Share
Hello,
I just set up my "new" NAS with OMV, it runs on an i3-6100 with 16Gigs of RAM.
I have two 18TB Seagate SkyHawk HDDs in ZFS mirrored with compression enabled and the OS runs on an old Samsung 120GB SSD.
And I am currently copping all my stuff over there.
So what is a good speed for that kind of NAS?
With my big BD rips I get about 60 MB/s, is that allright, seems slow to me.
The i3 is on 5% usage and about 8GB of RAM used.
I was more expecting like, double the speed, should I disable the compression?
It should be fast enough to stream your media without issue. Everything else is wasted.
So rise up, all ye lost ones, as one, we'll claw the clouds
This is on a gigabit network right?
Try using something like crystal disk mark to test the seed?
What compression mode? Almost always compression will make it faster, and thta cpu can compress with most settings much faster than the hdds can read and write.
Which OS?
You should be able to saturate gigabit (~100MBps) with that setup. There seems to be a bottleneck in the network somewhere. What devices are in the chain between source and server?
Compression is essentially free, performance wise (the algorithms are well understood and very fast).
Main System (Byarlant): Ryzen 5 1600X | Asus B350-F Strix | Corsair H80i V2 | 16GB G.Skill DDR4 3200MHz CAS-14 | XFX RX 5600 XT THICC II | Samsung 960 PRO 512GB / Samsung 970 EVO 500GB / UMIS SSD 256GB / Crucial MX500 2TB / WD White 7200RPM 8TB | Corsair CX650M | Mellanox ConnectX-3 10G NIC | Anidees AI-07BW Case | Dell U3415W Monitor | Microsoft Modern Keyboard
TrueNAS Server (Veda): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 4x 10TB WD Whites / 2x 1TB HGST 2.5" / 1x Samsung PM961 128GB SSD / 1x Kingston 16GB SSD | Seasonic Prime Fanless 500W | Mellanox ConnectX-3 10G NIC | LSI 9207-8i LBA | Fractal Design Node 804 Case (side panels swapped to show off drives)
Media Center/Video Capture (Jesta): Core i7-2600 | Asus H77M-PRO | Stock Cooler | 8GB No-name DDR3 | EVGA GTX750Ti SC | Sandisk UltraII SSD 64GB / Seagate 1.5TB HDD | Corsair CX450M | Hauppauge ImpactVCB-PCIe | Syba USB3.1 Gen 2 Card | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | (all-around awesome machine)
Laptop (Rozen-ZuluSony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Kingston 120GB SSD | Blu-ray Drive | (lived a good life, retired with honor)
Tablet (---): Samsung Galaxy Tab A 8" (crosses fingers)
Tablet (ReGZ)Asus T102HA (BIOS clock doesn't tick, loses time when sleep/off) (I kill tablets with disturbing regularity)
Tablet (Unicorn)Surface Pro 2 (battery will reset total capacity to current charge, leading Windows to think it's always 100% charged until it dies)
Tablet (Loto)Dell Venue 8 Pro (screen discoloration issues, wouldn't update to Windows 10)
Tablet: iPad 2 16GB (WiFi died, basically useless after that)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M (?) | HooToo USB 3.0 PCIe Card | NZXT H230 Case
Camera: Sony ɑ7II (w/ Meike Grip) | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance SDXC cards
Yep, NAS is connected with two Gigabit NICs via bonding, but PC has only 1Gbit.
AFAIK CrystalDiskMark doesn't work on network storage.
IDK, the standart compression of ZFS file format.
32 minutes ago, AbydosOne said:
Which OS?
Openmediavaulkt (Debian Linux)
Just an AVM Fritz!Box 7590 shouldn't be a problem everything wired with CAT7
37 minutes ago, Electronics Wizardy said:
Id turn off bonding, can cause issues, and won't help here
Yup it does, Ive done it many times. Need to run it as a non admin account.
36 minutes ago, AbydosOne said:
Then that won't be a issue
Did try that, made no difference at all, bonding is set upp in balance-rr, just in case my with uses the NAS at the same time.
Did just try only wotrks on C and D drive.
Is the network share a mapped drive?
Did you run crystal disk mark as a admin? Make sure uac prompts are on, and you click no when it comes up.
11 minutes ago, Electronics Wizardy said:
Id keep it off and use smb multichannel for better speed + multithreading + redundancy.
Ok, did work, with the select folder option, after running it as Admin, weirdly
Then the nas seems to be. Probaably a limit of the other drive or the program your using to copy things.
What?
The other drive is an Gen4 NVMe SSD
57 minutes ago, Plermpel said:
What?
How are you copying files? Try using robocopy with multiple threads.
Just tried that, makes no difference, also I build a NAS with pretty much the same config some time ago and he gets constant 112MB/s like it should be, with normal windows copy.
 Share
