Air Conditioner make PC go Brrr
CPotter
7 minutes ago, CPotter said:
God Alex makes me want to do bad things to my motherboard.
Tomorrow on LTT I used my house as a cooler!
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
That happened a few years ago
F@H
GPD Win 2
I was more envisioning sticking it to a metal wall.
System Specs
Peripherals
<Razer Mini>
*Brian the Electrician Theme incoming*
"A high ideal missed by a little, is far better than low ideal that is achievable, yet far less effective"
If you think I'm wrong, correct me. If I've offended you in some way tell me what it is and how I can correct it. I want to learn, and along the way one can make mistakes; Being wrong helps you learn what's right.
hey you guys what refrigerant is in this airconditioner? if you guys change it to r507 or r404 you can reach much deeper temps fyi. Heck even r290 Propane would work better than r407 what i think is in this unit.
i worked in the airconditioning industrie in germany its my what do you guys call it a education and training thing 😄 we call it an "Ausbildung".
CPU
Intel  i9 13900k
Motherboard
Asrock Z790 Taichi
RAM
Kingston Fury Beast DDR5 RGB 32GB 6000MHZ
GPU
MSI GeForce RTX 4090 GAMING TRIO 24G
Storage
Samsung SSD 980 PRO 1TB
Unraid NAS 10Gbit about 50TB HDD's, i713700k 64GB DDR5 crucial @ 5800Mhz
Win11 Workstation
Even having seen the intro I legit didn't recognise him with the glasses 😄
F@H
GPD Win 2
They're using R410A from what I understand which is a HBP refrigerant which is why the unit performs so poorly, they're also not using a correct metering device either, a crimped tube is pretty awful. A correctly sized capillary tube would be much better, or better yet us an EEV.
Yours faithfully
Yes i would sign that.
CPU
Intel  i9 13900k
Motherboard
Asrock Z790 Taichi
RAM
GPU
Storage
Win11 Workstation
Really enjoyed this video! I love these types of experimental, “let’s see what happens” videos that take place in the workshop. Would love to see more like this!
Always fun how complicated it can be to dumb down an AC unit, or other electronics for that matter.
It can be a fun challenge at times, but truly something that one shouldn't attempt unless one has a good few years of experience with electronics.
Though, this chip doesn't really have an "enable" pin, or rather, it is likely some transistor array that needs a bit more fancy control signals than a crude on/off switch.
But its actual text is on the other side of it, could take it off and look up the part number and take a look through its datasheet and see if it states something interesting.
Personally, I think it looks a bit small to be fair. Though, the compressor likely don't run much above 1 kW to be fair, so that is likely somewhat sufficient. Or there is a larger device elsewhere that does the actual job of inverting the DC back to three phase AC.
You''ll get it. Alex mentioned they're gonna use a 12th gen Intel proc in a future video. I do hope they're gonna do some Threadripper CPU as well, and perhaps a Ryzen 9 series proc too.
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
good you didn't have longer hair that day or a hat on, brian the electrician, at the end of 3:59. and safety gl... I mean glasses on 😛
when you see alex and brian become a team against linus and colin. next episode of tech mythbusters! oh...
No matter how much you try to fool the sensors, you won't fool the compressor which will draw liquid any moment there - not having enough thermal load, will make the refrigerant not completely boil inside the vaporizer (CPU block) and you'll get liquid inside the compressor. You won't notice it first, just after you burn out the motor's coils.
Ex-AC service engineer speaking from experience 🙂
6 hours ago, CPotter said:
What refrigerant did u use ? R134a ?
Im guessing it was as its the most commonly used nowadays. That is likely why u couldnt get below -20c. It only boils at -25c. You shoulda tried Propene R1270 which boils at -47c.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
So why not dunk the board in oil to beat condensation and water on the block and board?
Great video! One of the more polished "lets try something crazy without much planning" ones.
I mean - I know someone using his homes slab at the heat sink for his Server farm technically.
The compressor is too small. I like at the end of the video they where suggesting building a cascade unit. Yes, do that! 🙂
I never gotten into SS or cascade for all the work and energy required to run it, can just get some Dry Ice and actually get some decently cold temps -75c would be no problem even with a home made Dice pot.
Cool video though. Brings me back to many years ago when Drewmiester and Sparkey247 where building units locally by me. I got to watch several builds take place.
First off I enjoy watching these videos and appreciate Linus allowing this type of content creation. It is in my opinion the root of "Hacking" and exploration anyone can do.
1. Have you thought about using PLC to control the AC system?
2. I've thought about the condensation issue some regarding OC in general.... What if you placed a wall around the open test bench, sealed to the desk and a couple of inches / Cm above the tallest point of the test bench. Then pour Argon (Ar) into the walled container until it displaces all of the air. Would this no solve the condensation issue? There is most likely a better gas that's heavier but Ar is cheap and safe for experimenting.
@Squashy I have merged your thread into the official video thread.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Ohh wow, Brian and Alex really work very well together. I watched the Linus + Brian videos too, but I prefer this one.
