3700x with 3080 ti - will it bottleneck it ?
Hey.
I got to the point where people telling me to keep the 3700x for another year or 2 with 3080 ti.
And then upgrade.
Should I do it? will it bottleneck gpu badly?
Or just buy 5800x and sell the 3700 x
mainly this juice i need for gaming,.
CPU - AMD 5800XMotherboard - ROG STRIX B550-E GAMING , Memory  - G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 ,
GPU - NVIDIA GeForce RTX 3080 Ti MSI SUPRIM X 12G,  Case - 4000D AIRFLOW Tempered Glass Mid - Tower ATX Case - Black ,
Storage - Samsung 970 EvoPlus 500GB - Samsung 870 EVO 1TB + 6TB HDD,
PSU - Corsair HX1000 , Display -  ASUS TUF Gaming VG27A 165HZ + Dell 24 UltraSharp Monitor , Cooling - Noctua NH-D15 Black ,
Keyboard - Razer Stalker , Mouse - Logitec G502 Wireless , Operating System - Win 10 Pro ,
Sound - Logitech Z906 5.1 THX Surround Sound Speaker System
It really doesn't matter unless you're going for competitive benchmarking. That combo will play anything you can throw at it at a high level for a while yet. Possibly getting a few more fps with a newer CPU doesn't change the gaming experience.
Main system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance Pro 3200 3x 16GB 2R, RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
I am asking cause of this
https://www.cpuagent.com/cpu/amd-ryzen-7-3700x/bottleneck/nvidia-geforce-rtx-3080-ti?res=2&quality=ultra
That's on their test system at their settings. The potential difference will be different depending on your hardware and settings choice.
With the above in mind, if we take their numbers, are those fps difference going to affect your gaming experience? The lowest fps game they listed, goes from 131 to 148 fps. Is 131 fps unplayable to you that 148 fps will fix that? That's why I say it doesn't matter. The fps the system can throw out will cope with any game at sensible high end settings.
Out of interest, what is your display? 3080 Ti will really shine at 4k. It's a bit overkill for 1440p, but I wouldn't say no to one anyway 😄
Quote
yes
overkill doesnt excist. playing in gpu bottleneck, is playing in the world of LAG. Better do console then, much cheaper than PC.
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
What lag? At least for my gaming, since going G-sync, render lag has not been a problem. I can't speak for those who play games at like 400fps low settings/resolution. Consoles don't have the games I care about.
i want 4k 240 with 40series. :]
32 minutes ago, keavlar said:
Every system has a bottleneck. What matters is the needs of the particular applications or workflows you're doing. For gaming, it's hard to bottleneck a CPU at 1440p or above. At 1080p, you might create a bottleneck at the CPU, depending on the game. However, that's not necessarily a problem. So you only get 400 FPS in CS:GO instead of 425, for example. It doesn't matter.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
or he could just have 120-150fps in apex legends instead of 300fps, cause he is using a god damn slow 3700x
What in the world makes you think a 3700X would be remotely "slow"? You'd need a 11th gen+ or Zen 3 to beat it, so it's not exactly a slouch, even if it's a little old at this point. Plenty of people gaming just fine on much older, less capable hardware.
in gaming? 20% slower then intel 8th gen.
Slower than my 8700k.
You're cracked.
27 minutes ago, Chris Pratt said:
You're cracked.
just compare to 11600k at 4.6GHz. while 10600k and 8700k are essentially all the same while rocketlake is even weaker than both in some games.
¯\_(ツ)_/¯
So when using something like a 3080ti at 1080p difference will atleast be about 20% to my 5GHz, 4000CL17 overclocked 8700k.
Not that i needed the gamestar chart, https://www.gamestar.de/artikel/amd-ryzen-7-3700x-test-2021,3372889.html#ryzen-7-3700x-im-spiele-test-720p-aufloesung
Already knew where the performance of this CPUs where at for gaming.....
Ryzen 3000 was still well behind intel, a waste of silicon in terms of gaming performance. Good for productivity tho.
¯\_(ツ)_/¯
So when using something like a 3080ti at 1080p difference will be atleast about 20% to my 5GHz, 4000CL17 overclocked 8700k.
But plenty of gamers don't play at 1080p competitive settings. I'm a 1440p High-Ultra single-player gamer, so anything from a 3600 or a 8700K to a 5950X or a 12900K will be equivalent. A 2600 or 7700K might be a bit slower depending on the game, but even those are probably fine.
Yesterday I was playing Quantum Break at 1440p max settings on my 2060 Super and I was getting around 90-115fps with 20-30% utilization for my 5900X. None of the cores were maxed out. To lower the FPS in that game with a CPU bottleneck at those settings would require something much slower.
Sure, the 2060 Super is itself much slower than a 3080 Ti, but I'd probably run into the 170Hz refresh rate on my monitor before a 3700X would be the limitation in that situation. In those kinds of games, you don't really benefit from going over the refresh rate of the monitor, so for me, any CPU capable of pushing 170fps in a game is equivalent to any other CPU.
I dont care about FPS in single player games all that much, im happy to get 100fps in cool single player games. With gsync doesnt even have to be at that.
I also wouldnt worry about potential bottlenecks at high graphic settings or very high resolutions. Its not essential for me to get low latency gameplay in such games.
But when i get asked about if there would be a Bottleneck issue, i kinda have to assume that FPS are relevant.
If the OP can afford a 3080 Ti he can probably afford a CPU upgrade. The 3700x will definitely hold back a 3080 Ti depending on the resolution and desired FPS.
CPU i7 14700K | CPU Cooler Noctua NH-U12A | Motherboard MSI Pro Z690-A | GPU Zotac Airo RTX 4080 | RAM 32 GB GSkill Ripjaws V 4400
Mhz |
 Monitor Alienware AW2721D / Gigabyte M28U | PSU ASUS ROG Strix 850G
yea or he probably need all the money to afford the 3080ti.
Being able to afford an upgrade is necessary but not sufficient to justify one.
I'm using RAM running at DDR4-3200 CL16 for my 5900X. Considering that I over $550 on my CPU, I could certainly afford to buy a nicer RAM kit for $250.
But why would I do that unless it's going to give me a meaningful upgrade? For what I do with my computer, I wouldn't really benefit much from higher speed, lower latency memory. In the same way, if the OP isn't playing games that benefit from super high FPS, then even if affordable, the upgrade is kinda pointless.
14 hours ago, Chris Pratt said:
You're cracked.
Outside of a few titles, Skylake+++++++ with enough core count, cache, and frequency (overclocked 8700k, 9900k, 10900k, etc) generally do significantly outperform Zen 2 at gaming with a sufficiently strong GPU and the right settings; it's been a thing that's been explored ad nauseam on Gamers Nexus and several other outlets for the past several years.
Here's an example of a pretty CPU heavy game with only a 2080ti
As you can see, even a stock 8700k is ahead of all Zen2 here...it pulls ahead even harder with an OC. It will be close to the 5.1ghz 10600k result in this chart.
Here's another example of RTX 3080 CPU scaling...at 1080p/medium the gap between Zen2 and Skylake++++ is quite large.
https://www.google.com/amp/s/www.tomshardware.com/amp/features/nvidia-geforce-rtx-3080-ampere-cpu-scaling-benchmarks
A 3080ti will be worse.
So @DarkSmith2 is right in that respect. But otherwise, I tend to mostly agree with @porinaon this- that while it is faster at gaming, it's mostly academic in the here and now, because those settings are not realistic.
Lets take the best Zen2 result here against the best Skylake+++++ result....that's Zen2's 149 fps vs Intel's 178. That's more than 16% better with and old GPU, and the gap widens with better GPUs...is the Intel better? Yes. Does it matter? Not really, because who gets a 2080ti or better to play 1080p medium?
It's a decent way to predict on future gpu performance, so I do suspect that a Zen2 will perform even worse than Skylake++++ in this example with the 4xxxx/7xxxx cards...but who cares?
People who will be able to afford 4xxxx and 7xxx cards are not typically the ones who are gonna hang onto old cpu technology anyway. They won't be using 3700x's or 8700k's anyway.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
18 hours ago, keavlar said:
Hey.
And then upgrade.
Buy a 5800x especially as you don’t need a  motherboard upgrade. You’ll more than likely see a difference in performance even if it is a small one.
Mhz |
The V Cache Ryzen CPUs are just around the corner and will probably only need a BIOS update. It will be a more noticeable performance upgrade. They should be the last CPUs on AM4 as well. Wait for that instead.
well for most people not realistic, but there is a whole competitive gamer scene that cant get enough of sh1t like this 🙂
And also, most of them would also say ddr4 3200cl14 is bottlenecking hard in that GN benchmark on top of it. 😄
178/149=1.20, so its 20%. And yea i agree Medium settings is kinda weird. Low settings would make more sense. Still in GPU bottleneck with that one, guess the 2080ti isnt even overclocked either. KEK
  • 3 months later...
I have a ryzen 7 3700x paired with a rtx3080ti playing at 1440p with a 165hz refresh and it plays every game I throw at it with no lag or any problems at all! Also I get very high fps in every game I play if unlocked! I’m sure a better cpu would give me better fps and performance but if your just gaming I think your fine bro!! Personally I have had no issues  at alll and I get high frame rates in all games and mainly a smooth gaming experience with awesome visuals if wanted!
On 12/2/2021 at 4:55 AM, keavlar said:
This is a guess based on an overgeneralized ‘speed’ rating. The people who make these applets are always morons.  The easy way to know is to get recorded footage of a game being played on your desired setting and resolution uncapped, and see if the gpu or cpu core 0 is pinned to 99%, and/or if the fps is exceeding your monitor’s refresh rate.
short answer is no you’re fine.  3700x is plenty fast.
I edit the shit out of my posts.  Refresh before you respond.
