Pre-build or custom build
It really depends on how long you're willing to stalk around the market for a GPU.
My advice: Hunt for a GPU first, maybe something like a 6800XT/3080 in this price range. Then compile the list based off of that and what amount of money you have left over.
If you're willing to go down that route, I have a 2K USD build here - https://pcpartpicker.com/list/mcqn3Z
Which should fit your target range of 4K60-120. (mainly talking about esports titles) as the higher end 3xA titles will be hard to fit that performance range in this budget.
Of course parts like the Case and AIO are subject to change for your personal preference. Some alternatives could be P400A/Lancool II Mesh. For the AIO you could consider EK AIO, Galahad, or LF2
