First watercooled build, need advice.
49 minutes ago, archangel543 said:Hello,
i built my first watercooling system and have some questions.
1. the system makes bubbling noises. as i understand there still is air in the loop, how to get them out without having to shake or tilt the case?(corsair 1000 with 2X480 and 2X360 rads, very heavy)
2.the loop creates a vacuum, is this normal? every time i open the fill port the loop sucks in air.
3.is it best to have a fan curve for the pump or have it set to a fixed speed?
Thx in advance!
1) Unless u have a vacuum pump to pull the air to the res ull have to shift the system around to get the air out.
2) Yes this is normal, a slight pressure changes will occur as water temps change. This will be more pronounced whilst u still have air pockets shifting around the loop. When bleeding air from other areas of the loop, once the air gets into the res, open the top of the res to bleed the air, then repeat.
3) Higher the pump speed the better. Run it as high as u can handle noise wise. I for example run my D5 vario pump on its highest setting (5) and have done for ~7 years.
