GTX 1080TI fans not spinning
Guest BekesiBeni
Hi I repasted my MSI GTX 1080 Ti the card is working fine but the fans are not spinning despite of they are plugged in (not even when powering on). Linux says 0% and it is not lieing. Any ideas what have i done wrong?
do they spin under load? If the card is cool enough the fans are off.
Main PC:
CPU: AMD Ryzen 5 5600X | RAM:Corsair LPX 3200 mhz (16Gb)
Mobo:ASUS Strix B550-F Wifi | GPU: MSI RTX 2070 Gaming Z
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Be Quiet straight Power 10 500 watt
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Samsung 8 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
i couldn't test it i have to set a power limit until I have a bigger PSU but they should turn on for a little bit when i turn on the pc. They worked as far as i remember before i repasted it
what are the card tempatures? Can you check?
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
Starting with the 1000 series GPUs, there was a zero fan RPM mode. Fans would not kick in until a determined temp in the BIOS, usually anywhere from 50-60c depending on the manufacture. You can override this with 3rd party software, though I don't use linux so not sure whats available to do this.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
around 40 C but as i said they shouldn't they spin up when i start the pc?
No, not unless you have a custom fan curve set in software, otherwise by default fans are tuned to not spin until somewhere between 50 and 60c depending on the manufacture.
"Black Out"
Go into msi afterburner and set the fan to 100%, if it works set it back to auto and you're fine.
If it doesn't spin when manually set in afterburner then it ain't working
