Search In
  • More options...
Find results that contain...
Find results in...
Are m3 35mm screws work for long fan radiator screws?
Chriszzz
 Share
Hi,
I just want to know if m3 35mm screws work like for long fan radiator screws. I need slightly longer screws to mount the fan to radiator.
Normally those are imperial rubbish.
You can install metric screws into imperial threads but that will damage it and is far from ideal.
But will it work?
Probably but is it worth destroying the screw thread?
The right one would be a UNC 6-32.
On 11/30/2021 at 4:44 PM, Chriszzz said:
thanks i will source a UNC 6-32
this is my problem when i get a 360 radiator i want the screws to go through the fan and screw into the radiator but my 30mm long screws, won't be able to attached to the radiator due to the bracket.
this is my problem when i get a 360 radiator i want the screws to go through the fan and screw into the radiator but my 30mm long screws i get from cooler master, I won't be able to attached to the radiator due to the bracket.
i can only attached the fan into the bracket..but not through the radiator....
so i found these, G304 Stainless 6-32 UNC Imperial Coarse Pan Phillip Machine Screw BSW are these similar to the *6-32 screw for computers?
sorry i'm not familiar with screws. here's the reference.
Should be fine.
G304 stainless ist the material
6-32 UNC the thread
corase pan phillip the screw head.
If you are unsure about length order the longer version and cut it down to size if needed.
6 hours ago, James Evens said:
Should be fine.
6-32 UNC the thread
This one is about 38mm length should be enough thank you
 Share
