Search In
  • More options...
Find results that contain...
Find results in...
PC fans will spin but not picture on display
plzhelpmypc
 Share
I just finished my PC bulid and my computer won't show anything on the display please help
Specs:
i5 10400
Stock Cooler
Asus Prime Z590-P
16gb 3600mhz Corsair Vengeance DDR4 Ram
PSU 600w EVGA Bronze
NO GPU just iGPU
Western Digital 500gb m.2 ssd
Are using the hdmi or the display port on your board?  If possible, try the other one (if just temporarily).  If it allows you to get into the bios, you might be able to select a default output.
I'm very generous with the likes I give out on here; you should be, too.
I never believed in orthopedic inserts, but then I got a pair.  Now, I stand corrected.
My friend gave me his Epi-pen as he was dying.  It seemed very important to him that I have it.
Why do cows wear bells?
Because their horns don't work.
When that happens to me I first check to see if something isn’t connected properly.
 Share
Newegg
