Good CPU cooler for 11600K
Go to solution Solved by PenguinMaster,
I ended up getting the be quiet dark rock 4 because I had an additional 15% off coupon and I have a lot of be quiet stuff and I like the quality / low sound of them.
I am planning on building a new system for VR. I know you can't get GPUs at the moment so for now I'm buying all the parts except the GPU and hopefully some time next year the prices will be sane again.
My question is what is a decent CPU cooler for the 11600K? I'd prefer to stay at around or under $50 but the cpu cooler that seems the most recommended is the Noctua NH-U12S chroma.black for $79.95-. Is it worth all the extra money? It seems kind of expensive.
Thanks for anyones input
If you need me to follow up on something, please quote or tag me.
depending on what noise and overall quality you're preferring to stay around, the nice and cheap Vetroo V5 can do a pretty good job at cooling an i5 CPU. Gamers Nexus recently published a CPU cooler roundup and Steve noted that this cooler is comparable to the NH-U12S in cooling potential, while the Noctua cooler has some key improvements with things like noise and warranty service.
My girlfriend uses the Vetroo V5, and while I can't compare the cooling experience directly for you (she uses a Ryzen 3 2200G), I can say that the installation process is far from frustrating.
Primary PC:
@Tech87@Fasauceome
These are the CPU coolers I'm between:
$57.40 - be quiet! Dark Rock 4
$66.90 - be quiet! Dark Rock 4 Pro
$79.95 - Noctua NH-U12S chromax.black
Which would you guys recommend?
26 minutes ago, PenguinMaster said:
@Tech87@Fasauceome
The dark rock 4 will be able to handle an i5-11600K with ease
Primary PC:
My vote goes for Scythe Fuma 2. It has been a good cooler and was also recently highlighted in GN's latest coolers video.
Also inexpensive at around $60.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL- C12 Pro, 2x TL-K12, SYY-157
Asus Crosshair VIII Dark Hero | 4 x 8GB G.Skill Trident Z Mix @ 3733 14-14-14-34 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X, 2x SN770, Asus Hyper M.2
EVGA SuperNova 750w | Fractal Torrent Compact | 1x Phanteks T30, 1x TL-B12, 1x TY-143
