Search In
  • More options...
Find results that contain...
Find results in...
Need help with a new motherboard as im not that technical with the performance and stuff
is this a good replacement motherboard for my set up since I kind of broke my current one
What I got is a
CPU - Intel Core i7-9700K CPU 3.60GHz
GPU - Geforce GTX 1080TI (STRIX GAMING)
PSU - Corsair RM 850X (850 WATTS)
RAM - Corsair VENGEANCE LPX 16gb 3200MHz (DDR4) X2
The old motherboard - https://www.amazon.co.uk/dp/B07HM3MD1D/?coliid=IDHZ2V9942IP&colid=36OB739UVUK40&psc=0&ref_=gv_ov_lig_pi_dp
The new motherboard - https://www.amazon.co.uk/gp/product/B07BRM1RWD/ref=ask_ql_qh_dp_hza
Any help is much appreciated
Quote
Old motherboard: MSI MPG Z390 GAMING EDGE AC
New Motherboard: ASUS ROG STRIX B360-F Gaming
Without getting too far into the specs differences, The STRIX B360-F Gaming supports the 9700K starting with BIOS Version 1402, released 2019-04-25.
The other listed components will be compatible as well.
Main: AMD Ryzen 7 2700X, Nvidia GTX 1080 Ti, 16 GB 3200 MHz DDR4 Fedora 35 x86_64
Secondary: Intel Xeon W3680, NVIDIA GeForce RTX 2060, 24 GB 1333 MHz DDR3 Windows 10 Home x86_64
Server: 2x Intel Xeon X5670, 72 GB 1333 MHz DDR3-R Ubuntu Server 20.04.3 LTS x86_64
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x Windows 11 Home 21H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4 Windows 10 Pro 21H2 x86_64
@Digideath when I used some compressed air it liquefied and I think it got on the motherboard and it damaged one of the links (Don't know if that's what it called) from the cpu to the ram ports and it blue screen every now and then since it happened
EDIT - by post you mean dose it start then yes but it just blue screens randomly and its just getting annoying
Edited by BFD_SURVIVOR
57 minutes ago, BFD_SURVIVOR said:
@svmlegacybut would you recommended the motherboard or do you have anything else you recommend to replace it?
Sorry, I don't have any experience with the LGA1200 platform, and can't speak to it.
 Share
