First time installing a cpu cooler myself. Are these temps okay? I5-12600K and Noctua nh-u12a
Solved by BiotechBen,
6 hours ago, Yerbluez said:Thanks to all who responded. @dilpickle and @Tech87 I have the Noctua NH-U12A chromax black air cooler and I can confirm it comes with a mounting kit for LGA 1700. So the cooler fits, I was just a bit more concerned about my install. I will download cinebench and do a benchmark? @BiotechBen and @kraken, I appreciate that input. I know these are supposed to run hot. I will check thermal paste at some point, but in the meantime is there a max temp I should be careful of with this Alder lake gen?
T-max is usually 105C for those chips, so having it in the upper 70s and low 80s on a smaller air cooler is about what is to be expected. An NH-D15 iirc put it somewhere in the mid 70s to low 80s under full load when LTT tested it.
