I am planning on building my first self-build pc and want to know if the parts fit
Solved by brob,
CPU with integrated graphics work well with discreet GPU. If desired iGPU can usually be disabled in the BIOS.
The i5-1140 would offer marginally better performance. Mostly I made the suggestion as it would allow use of the system while waiting for GPU pricing and availability to improve. If the plan is to hold off acquisition until a GPU is secured, then you will need to re-examine configuration options at that time.
