Search In
  • More options...
Find results that contain...
Find results in...
Help with starter build gpu recommendations for minecraft and roblox.
Finalcountdown
 Share
Budget (including currency): $100-$300 CAD
Country: CANADA
Games, programs or workloads that it will be used for: minecraft, roblox
Here is the build I just need to find a gpu to fit it for a couple hundred dollars
https://ca.pcpartpicker.com/user/Finalcountdown21/saved/zjhn6h
Component   Selection Price
CPU   1dd09dfdc581be6224a323d49d714c7f.256p.jpg AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor $284.75 Buy
Motherboard   6ee60c91fb16b4bddf49fc49cd080a16.256p.jpg Gigabyte B550M AORUS PRO Micro ATX AM4 Motherboard $139.99 Buy
Memory   aa34b3c28154431c4b8ebd2f90a647e4.256p.jpg Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory $119.50 Buy
Storage   83fc222cffd82fb104d78992b60759eb.256p.jpg ADATA XPG GAMMIX S11 Pro 512 GB M.2-2280 NVME Solid State Drive $69.99 Buy
Case   51BARwNk2iL.jpg Thermaltake Versa H18 MicroATX Mini Tower Case $66.99 Buy
Power Supply   fef7512dace78a5d11d0fea87eb8a7d6.256p.jpg SeaSonic FOCUS Plus Platinum 550 W 80+ Platinum Certified Fully Modular ATX Power Supply $69.98 Buy
Operating System   f5e3c78aadf16d536c31b0fa088c8306.256p.jpg Microsoft Windows 10 Home OEM 64-bit $116.75 Buy
Case Fan   2d05feb8554dc931209a84440ad9a157.256p.jpg ARCTIC P14 72.8 CFM 140 mm Fan $12.99 Buy
Monitor   8867fe547a8f02883838f2ca65220fa6.256p.jpg Asus VP228HE 21.5" 1920x1080 60 Hz Monitor $156.01 Buy
Keyboard   022f3a972f3755b777cc7b640170bad0.256p.jpg Corsair K55 RGB Wired Gaming Keyboard $49.99 Buy
Mouse   1e8c3800a012015b0400211b5d370aa0.256p.jpg Logitech G403 HERO Wired Optical Mouse $59.93 Buy
Total: $1146.87
You aren't gonna get a GPU new that's better than the iGPU in the 5600G. You might be able to get a used GTX 1060 in that price range, but it would be extremely overpriced, and for Minecraft and Roblox the 5600G's iGPU is fine.
Monitor is not a good option. Rather a bit pricier, yet much better Gigabyte ‎G24F-SA
https://ca.pcpartpicker.com/product/Cnwypg/gigabyte-g24f-sa-238-1920x1080-170-hz-monitor-g24f-sa
60Hz really is bad, at that price point especially.
Gigabyte ‎G24F-SA is 170Hz
In some respects it's the most important element for a great experience...
... but I'm no expert.
do you have any cheaper options than the Gigabyte ‎G24F-SA is 170Hz its for  my friends 10yo first PC.
Not a much cheaper and not as good - https://ca.pcpartpicker.com/product/22VmP6/acer-nitro-qg241y-pbmiipx-238-1920x1080-165-hz-monitor-umqq1aap01
Maybe consider using un-actiavated Windows for a while instead? You don't lose too much functionality with that, but Gigabyte ‎G24F-SA  would fit into budget then.
Since it will only be using integrated graphics would going from 21.5'' to a 24'' be worse performance though?
No. Only the resolution matters in this case.
1080p both.
But I think when there arrives a dedicated GPU, the monitor still is very good for the experience.
 Share
