Search In
  • More options...
Find results that contain...
Find results in...
USB Drive Issues
TechDerek
 Share
I put Pop OS on a USB to try out the Linux experience, but when I was done I used Rufus to make the device non bootable it says " The request could not preformed because of I/O device error." The USB stills works as a Pop OS live USB. How can i fix this and did I do something wrong?
If anyone has anything to say about how I may be able to fix this, please put some input in. I need this fixed. Thank you
  • 2 weeks later...
 Share
