Fractal Meshify 2 or NZXT H710 ?
Solved by suedseefrucht,
54 minutes ago, Indian pc builder said:Components equal intel i9 undisclosed gen and nvidia rtx 3080ti
For custom watercooling or an AIO watercooler´, I would go for the meshify 2.
Maybe the compact version if you dont need the space for a pump or a reservoir.
If you go for aircooling, I would go for the fractal design torrent.
So your airflow cant escape through the top and has to go to the back of your case to cool the CPU and grapics card.
