Search In
  • More options...
Find results that contain...
Find results in...
Gtx 770 Vram OC help (artifacting)
MrP6k
 Share
So i bought a 2nd hand leadtek gtx 770, and i tried OCing it's Vram to 3800mhz, after a bit of unigine heaven my display crashed with some red block artifacts
Is it normal for a gtx 770 to not be able to push 3800mhz on vram? And is it normal for artifacting to happen when it can't?
Edit: also, does anyone know any good VRAM testing apps?
an iGPU gamer looking to upgrade
Correct, if the OC is on the edge of not being stable like that, artifacting can happen.  If pushed a little further it will just crash.
I'd just use it without an OC.  You're not getting a huge bump in performance with one even if you somehow get it to run at 3800.
Emma : i9 9900K 5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200Mhz - 750 EVO 512GB + 2x 860 EVO 1TB (RAID 0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Corsair Virtuoso SE - Logitech G910, G502 - Cooler Master Universal Graphics Card Holder
Plex : Ryzen 5 1600 - Gigabyte B450M-DS3H - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1900 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Samsung 27" + Dell 24"
Raven:  Intel i3 10100F - ASRock H410M-HDV - G. Skill Ripjaws V 16GB 2666Mhz - MSI 1050Ti 4GB - Inland 256GB SSD + Toshiba 2TB HDD - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Spectre 24"
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM, 512GB NVMe SSD, 1050Ti, 4K touchscreen
MSI GF62 - i7 7700HQ, 16GB 2400 MHz RAM, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti
Not all cards are equal, cards with Samsung GDDR5 VRAMs are known to overclock significantly higher than Hynix or others. I personally dont bother with VRAM overclocking as your overclock might be stable until the very last second you kill one of the vram chips.
mY s YsTeM iS Not pErfoRmInG aS gOOd As I sAW oN yOuTuBe. WhA t IS a GoOd FaN CuRVe??!!? wHat aRe tEh GoOd OvERclok SeTTinGS FoR My CaRd??
 HoW CaN I foRcE my GpU to uSe 1o0%? BuT WiLL i HaVE Bo0tllEnEcKs? RyZEN dOeS NoT peRfORm BetTer wItH HiGhER sPEED RaM!!dId i WiN teH SiLiCON LotTerrYyOu ShoUlD dEsHrOuD uR GPUmy SYstEm iS UNDerPerforMiNg iN WarzONEcan mY Pc Run WiNdOwS 11 ?woUld BaKInG MY GRaPHics card fIX it?
 MultimETeR TeSTiNG!! aMd'S GpU DrIvErS aRe as goOD aS NviDia's
I'm really just doing this to test and make sure this card doesn't die on my like my last one did. Do you happen to know any good VRAM testing programs?
I'm also panning on using it stock, but for the first 2 days i want to have it overclocked to make sure that this card isn't on it's last leg
OCing it may just make it's leg the last one.  Now how I'd stress test an old GPU.  You can't know when it is on it's last leg, and pushing it hard can break it where regular usage wasn't going to.
Besides, just because it may handle an OC for a couple days doesn't guarantee anything at all.
Other Tech:
Can you explain how you'd test old GPUs then?
 Share
Newegg
