motheroard New Build not turning on, Need help identifying the issue
Solved by emosun,
alright well so long as all the connections are connected and everything is supported and you aren't getting any diagnostic leds or beeps and the gpu is known to work then it can likely just be a DOA board. Just make sure everything works in a different build to be sure but that would be my conclusion.
ID0 ·
Posted in Networking1 -
eviohh ·
Posted in Troubleshooting3 -
5
IhateAMDDRIVERS ·
Posted in Troubleshooting2 -
SashaSanguine ·
Posted in General Discussion6 -
9
Redsin ·
Posted in Graphics Cards3 -
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards12 -
1
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
