mining on a gtx 660 ti and a i5 10600k
Gabin
what is the best type of coin to mine on a gtx 660 ti and a i5 10600k?
it wouldnt be on 24/7 only will in at school or sleeping, i do not sleep in the same room as my pc.
what would you recommend mining?
I dont think any mining pool accept these two, they are so slow... and inefficient too, you wont make a profit on this unless you get free electricity even if you did start mining.
Desktop benching:
Yea like stated, its gonna cost you money to attempt to do it. Can do it with some alt coins on the cpu but isnt gonna be worth the time in any significant way.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
