Choosing a 1440p Monitor…
JayDM
Having a PC built and I’m having trouble choosing a monitor.  Looking for 1440p, 27 inch, 1ms gtg, 144Hz+, G-Sync compatibility.  Here’s what I’m stuck between.
MSI Optix G273QF 16:9 Aspect Ratio Anti-Glare Super Narrow Bezel 1ms 2560 x 1440 (QHD) 165Hz Refresh Rate Tilt Adjustment Nvidia G-Sync Compatible 27" Rapid IPS Gaming Monitor
LG 27GL850-B 27 Inch Ultragear QHD Nano IPS 1ms NVIDIA G-Sync Compatible Gaming Monitor, Black
MSI QHD Rapid-IPS Gaming Non-Glare Super Narrow Bezel 1ms 2560 x 1440 165Hz Refresh Rate Adjustable Arm G-Sync Compatible 27” Gaming Monitor (Optix MAG274QRF), Black
ASUS TUF Gaming 27" 2K HDR Monitor (VG27AQ1A) - WQHD (2560 x 1440), IPS, 170Hz (Supports 144Hz), 1ms, Extreme Low Motion Blur, Speaker, G-SYNC Compatible, VESA Mountable, DisplayPort, HDMI
VIOTEK GFI27DBXA 27 Inch 180Hz QHD 1440p 1ms Gaming Monitor with HDR, GSYNC/FreeSync Compatible, HDMI 2.0, DisplayPort 1.4, VESA, 141% sRGB & Over 1 Billion Colors – 3 Years Zero Dead Pixels
AORUS FI27Q-P 27" 165Hz 1440P HBR3 NVIDIA G-SYNC Compatible IPS Gaming Monitor, Built-in ANC, 2k Display, 1 ms Response Time, HDR, 95% DCI-P3, 1x Display Port 1.4, 2x HDMI 2.0, 2x USB 3.0
Not sure what’s my best pick and thought I would see if someone with some more hands on experience or just greater knowledge could steer me in the right direction.  Open to other suggestions, everything above falls between $300-$400, like to stay somewhere between there but would go 450-475 if anyone thinks I’d be getting something far better for the extra money.
Thanks in advance.
There are few individuals in the universe who know more about monitors than Tim from Hardware Unboxed. He created this guide for just this type of situation.
For me, I went with the Gigabyte M27Q based on his recommendation in an older video, and I've been using it for 7 months now. It's a great monitor, and also wins the value pick in this round-up, but if you're looking at possibly spending more, there are better options.
53 minutes ago, JayDM said:
just gonna shorten the list for ya, 1ms is pure marketing
best value pick m27q, unless you can find the LG for 275usd
best text/comfort LG 27GL83A-B/850B, low contrast but comes with srgb clamp
best gaming/color/overall msi 274QRF-QD (not the base non-QD version), cheapest argb high refresh option on the market.
fi27Q-P is just slightly worse overall.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
I went for the MSI 274qrf-qd got it for 405 at new egg, I think I’ll be happy with it.  Thanks guys.
The MSI 274QRF-QD is the best if you have an i1 Display to make a color profile for it. If you don't, The LG GP850 probably is. I was able to find one on Amazon's Refurb program for about $350.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
Recent firmware updates added an sRGB mode. So oversaturation for standard content is not a problem anymore.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
That's great, but it likely won't be remotely close to accurate color targets. With monitors like this, the difference between uncalibrated, eyeballed, and actually calibrated, is not subtle.
Close enough for most people. Of course if you're dependant on accurate colors for work etc. you should own and use a calibration device either way.
