Ubiquity Dream Machine with a UDM PRO
Solved by Electronics Wizardy,
35 minutes ago, NoblekingZ said:There is one line runing into the home that is a FTTC line (a copper wire) which terminates into a RJ11 connection (inside the home) so I would have to get a converter to convert it from RJ11 to RJ45 to plug into the Ubiquity Switch.
so you have dsl. Then plug the dsl modem into the udm pro or a switch that has vlans setup right.
33 minutes ago, NoblekingZ said:A modem is required after the connection comes into the home which is basically what I think the UDM-Pro does not support?
yea your gonna need a modem to convert the dsl into ethernet.
