do routers work with a usb hub splitter?
acepro71
Do they have anyone tested it or can test it for me?
I own TP-Link WiFi 6 Router AX1800 Smart WiFi Router (Archer AX20) however do not have a hub to test it with...
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
What are you planning to do here?
USB hubs are for increasing connectivity for USB devices. For a mouse and keyboard which are low power/bandwidth devices, that's not a problem, but the more bandwidth and power required, then all devices will have to share what's provided over the single USB uplink.
If you're planning to attach multiple USB storage devices to your router's USB port, check to make sure what is the power output being supplied on that port. Might be less of an issue for drives on independent power supplies.
If you're planning to attach multiple USB storage devices to your router's USB port, check to make sure what power output being supplied on that port. Might be less of an issue for drives on independent power supplies.
I want to connect one external hard disk and one usb printer.
I read about some people use USB hub and it works on their OpenWRT router. As @Falcon1986said, especially on external HDD, you definitely need a powered USB hub.
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
Intel Xeon E3-1225 v2 || ASRock B75M Motherboard || MSI GeForce GTX 1650 Gaming X 4G || Hynix 2x8 GB DDR3 1600 MHz RAM || 480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD || be quiet! System Power 9 500 W PSU || Cooler Master T20 CPU Cooler || Samsung S19D300 Monitor || Fantech X6 Knight Mouse || VortexSeries VX7 Pro Keyboard
Samsung Galaxy A34 5G
8GB RAM, 256GB Internal Storage, 128GB SanDisk Extreme, and you could find the rest of the specs on the interwebz lol
Lenovo ThinkPad L390 Yoga
Intel Core i5-8365U || 8 + 16 GB DDR4 (don't ask, gf bought me the 16 GB RAM as my birthday present lol) || Samsung 256GB SSD
Personal Server: CasaOS, Home Assistant, ESPHome, Jellyfin.
AMD E-350 || 3GB DDR3 || 120GB random SSD || 1TB Toshiba HDD
Audio
Redmi TV Soundbar || KZ EDX Ultra + KZ APTX Bluetooth Module || JCALLY JM6 CX31933 DAC
Yeah, a powered hub should be fine.
Then again, I saw your other thread, those network streaming functions built into a lot of home grade raters are sometimes complete garbage. You might be better off just plugging this HDD into the TV.
Eh, I tried my OpenWRT router as a NAS, plugged in the external HDD with NTFS on it.
Ended up just using my old laptop, using Windows 10 as a NAS. Just too much to do on Samba/such (two days of freaking Samba permission troubleshooting and still can't even get it work decently sucks) when you can simply share your folder over Windows.
Now I don't have to fight over external HDD just to watch movies when 3 of us simply stream it out the laptop.
Diccbudd PC
Audio
Getting it to work isn't generally hard, getting it to work well is impossible - routers are grossly underpowered as a NAS.
Even ignoring the weak CPU, a good NAS has Gigabytes of RAM to cache storage access for improved performance.  I have 32GB RAM in my NAS, currently sitting with 18.9GB of cache.  A Raspberry Pi makes a much better budget NAS than a router.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
