Search In
  • More options...
Find results that contain...
Find results in...
Thoughts on EVGA Supernova G6 & P6 1000w?
 Share
EVGA has recently released a pair of new PSUs I am interested in, specifically the Supernova G6 and P6 1000w. Both are only 140mm long. Aside from that, there doesn't seem to be much information out there about them. Neither are on the PSU tier list yet. Does anyone know how these stack up both with respect to my old G3 1000w & other PSUs?
Supernova G6
Supernova P6
Thanks for your time!
well nobody really knows, ubt if i had to guess I think any new psu from EVGA  will beat the meh G3.
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
Actually, some bodies know.
https://www.tomshardware.com/reviews/evga-supernova-1000-g6-power-supply-review
https://www.tomshardware.com/reviews/evga-supernova-850-g6
https://www.tomshardware.com/reviews/evga-supernova-750-g6-power-supply-review
It's a good PSU. No reviews on P6 yet but i expect it to be pretty much the same thing with upped efficiency.
Tag or quote me so i see your reply
3 hours ago, Juular said:
Thank Juular.
I had come across that review previously. I was hoping for a couple more to build a sort of consensus before I pulled the trigger on it. That said, anything based on a Seasonic design should be a decent piece of hardware.
Wrong conclusion. It's good because it has reviews which proved that it is, not because it's Seasonic.
 Share
