Search In
  • More options...
Find results that contain...
Find results in...
Need help setting up an NDI
Hey Everyone,
I need some help setting up an NDI from and Ipad pro 11 Wifi to my Lan PC. The software I'm using is NDI.TV and when I use the software it wont detect the iPad unless I also use a wifi adaptor (really cheap and weak signal one). I also tried to use the NDI access manger and manually entered the IP address but still nothing. I do have a google nest network set up around my house but I don't know if this will affect the detection? Does anyone know if I've missed a step?
 Share
