CPU Core Temp much higher than CPU Socket Temp - i7-10700k, Corsair XTM50
Solved by SorryBella,
8 minutes ago, Harsh555 said:Should I tighten all the way or stop when I feel it's secure?
Fingertight, when you start to struggle screwing it in. Also, do it in a criss cross pattern and make sure you add the pressure evenly by screwing each screws turn by turn.
KageSong ·
Posted in Programs, Apps and Websites1 -
Regnoc ·
Posted in Networking2 -
BoomerL4D ·
Posted in Laptops and Pre-Built Systems1 -
KaliberKitsune ·
Posted in Mobile Gaming4 -
Stevenfred ·
Posted in Troubleshooting5 -
2
