5700xt Gigabyte 5700xt replacing shroud with 2x120mm case fans
https://www.amazon.com/GELID-SOLUTIONS-PWM-Adapter-Cooler/dp/B005ZKZEQA
This thing works on gigabyte cards since they are still using the same connector from before.
As for fans yeah p12's will do but this is one of the situations where getting some nice noctua a series stuff won't hurt at all.
As for power 0.08*2 = 0.16 which is less than the 0.35 A the stock fans need. So all good there.
People usually just set one speed for the fans and that is it when they use the motherboard. But gigabyte does work with that adapter on almost all of their cards. The 5700xt should be included in that.
Oh and golden tip STORE THE FANS AND SCREWS IN A BAG AND IN A GOOD BOX DO NOT LOOSE THEM. If you ever want to sell the card put that stuff back on because a diy'd card like that is basically unsellable.
