Advice regarding case fan purchase
Solved by jaslion,
The s340 just sucks for airflow and is another negative airflow case to get the best performance out of it. So basically stock config with the best fans you can afford which would either be the Arctic p series or the noctua nf series.
EzioWar ·
Posted in CPUs, Motherboards, and Memory13 -
neSSa ·
Posted in Build Logs0 -
El Gurra ·
Posted in New Builds and Planning2 -
Ozzieh_man ·
Posted in New Builds and Planning8 -
3
14
3
ViciousRaptor ·
Posted in Troubleshooting7 -
KennethC90 ·
Posted in Cases and Mods1
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
