Posted October 19, 2021 so basically i recently got a gtx 1070 and it has 2 8 pin connectors needed, right now i only have a 8 and 6 pin and also i am using this gpu with the 8 and 6 pin and today i went into a game (dead by daylight) and so i loaded in and it was showing 360p because it couldnt run it properly. tomorrow i should be getting a adapter for the 2 pin. but i am not worried about that im scared that my gpu is not gonna work well even with the 2 extra pins needed, so will the 2 pins that are needed make that much of a difference? (i have a 650 bq psu) so is my problem the psu, the 2 pins or the gpu itself? help Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 19, 2021 Maybe the problem is you because you lost one PCI-e cable. EVGA 650 BQ has two PCI-e cables with one 6+2 pin and one 6 pin each. Where's your second cable? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 19, 2021 Author i have a 6+2 pin and one 6 pin and my card requires 2 8 pins im pretty sure thats all that came with it though... Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 19, 2021 No, the PSU came with two cables. Take a look in the box and find out on the product page https://www.evga.com/products/product.aspx?pn=110-BQ-0650-V1 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
