HELP ME WITH MY BUILD/RATE IT
Hello fellow gamers i am thinking of building this PC, please let me know if something is bad here or can be done cheaper + i am not looking to build the best of the best computer just something i can upgrade more in the future.
Thanks for help in advance 🙂
Budget (including currency): 10,000 NOK = 1150 USD
Country: Norway
Games, programs or workloads that it will be used for: Mostly games such as Escape from tarkov, Apex legends, CSGO and new battlefield 2042
Other details:
Here is the PC i want to build
CPU: Intel Core i5-11600K 3.9 GHz 6-Core Processor
CPU Cooler: Asus ROG RYUO 240 RGB 80.95 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z590-A GAMING WIFI ATX LGA1200 Motherboard
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Storage: Western Digital WD_BLACK SN750 SE 1 TB M.2-2280 NVME Solid State Driv
Video Card: Sapphire Radeon RX 5600 XT 6 GB PULSE Video Card /Already have it/
Case: Phanteks Eclipse P360A ATX Mid Tower Case ($79.98 @ Amazon) /Already have it/
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Country: Norway
Other details:
wouldn't go for intel, and also i would recommend a corsair or nzxt aio cooler
Country: Norway
Other details:
also 1 tb of storage runs out quick so i would recommend a 1 or 2tb sata ssd
Overpriced
Rog aios are overpriced asf, corsair h100i platinum will obliterate it, though if you have the space then you can get a better value option like liquid freezer 240-360, if you arent overclocking a cheap 4 heatpipe tower like se 224 xt or freezer 34 will suffice
Rgb pro is overpriced trash, find some cheaper rgb rams instead of overpaying for the corsair brand or atleast get some good overclocking rams like tridentz rgb or tridentz neo
Bad
11600k is basically the same price as a 5600x and with a 5600x you can get a cheaper mb and not have to overclock it to harness its performance unlike the 11600k, and good luck trying to overclock an 11600k with a sad 240mm aio
