How many PINS for cooling + ARGB
Alecsandru
Hello Guys,
My CPU is i7 9700F, and my motherboard is Asus PRIME B365M K.
I want to buy an ARGB cooler, but I’m not sure if the PINS are enough.
I have 3 options:
ID-COOLING SE-224-XT (default version) that says 4PIN .
ID-COOLING SE-224-XT v2 ARGB, that says 4 PIN / 3 PIN ARGB.
Aqirys URANUS (also ARGB) , that says 4 PIN + 3 PIN ARGB.
I know the motherboard has 4 PIN for CPU Fan, and in the specs it says : 2x 4-pin Fan Header. (My case only has 2 fans, one in the front, one in the back, and supports 2 more upside).
Will I be able to use the ARGB versions, or should I stick to the 224 XT non-argb ?
And if I want to get the 2 extra fans, will I be able to use them? And if yes, they have to be normal ones or can they also be ARGB?
3pin argb seems odd but I think from looking at it they mean a 3 pinned header but that is 4 pins wide since it's aura sync compatible for the id cooling.
Doesn't matter however since your board doesn't have a argb header any way. So you'll have to get a controller like the icue commander or something similar if you want a argb cooler + rgb fans.
So the motherboard would let me use a normal cooler + 2 extra fans for the case, but they cant be ARGB unless i buy a controller?
I saw that the motherboard says it supports 2x4 PIN Fan Header, but it highlights the CPU Fan as one of them, so I am worried about only being able to use the CPU cooler + 1 extra case fan instead of 2 .
just buy a fan splitter
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
