Strange clicking noise, gets louder when playing.
Solved by CommanderAlex,
2 minutes ago, ShadoWalkeR said:Does that indicate the card is dying or it's normal, the card is the only old component here it's a 1080 TI but was unused for most of it's life.
Coil whine is normal and does not affect the performance or reliability of the graphics card. The noise is from transformers/inductors vibrating at a frequency that falls within the human range of hearing, about 20Hz to 20,000Hz.聽
