MSI GF65 thin temps +95c (FIX)
On 10/15/2021 at 3:13 AM, jaslion said:World of warships is a very easy to run game and isn't heavily threaded so your system doesn't have to put much effort into it.
Battlefield on the other hand can literally 100% your entire system and then some so the heatload goes up like crazy.
Don't remove the back panel that will break your laptop due to shorting something, structural integrity issues (no joke typing on a thin laptop without the back literally can bend them), parts coming loose,... Just don't do that it has enough vents as is.
Userbenchmark is bs so don't trust it.
Your issue literally is a laptop with a weaker cooler that has a too high energy consumption and heat load cpu in it. There is nothing you can do about it that you haven't already done or are going to do with the thermal paste (please don't do liquid metal in a laptop its a bad idea).
It's a situation you just can't win. Best you can do is lower the power target in windows to something like 80% for the cpu and forcibly make it run slower so it gets less hot.
**WHAT TO DO** So I had just replaced factory paste for grizzly thermal on cpu and gpu of course! the factory paste was just AWFUL look at my above *edited post!!! after replacing factory paste and clearing out the debree in the fans. When running heaven benchmark (lowest graphics & everything turned off for lowest quality my temps use to run 80c on cpu and 70c on GPU i just ran benchmark and just by already noticing the fans blowing out 2x as much air as it was when i first got this laptop 8 months ago i figured it dropped some but i didnt realize how much it was going to drop! -20c on the CPU and -10c on the GPU (same settings)! Just make sure to take apart fans to clean thoroughly and i highly recommend obviously is to get a single gram of grizzly kyronaut thermal paste on amazon (1 gram should last for 5-10 applications of both cpu and gpu). i also have new OwlTree thermal pads on the way those should help by another couple celciius or so since i re-used these factory pads one being all dried up and a couples being ripped and torn from copper pipe removal! GUYS IF YOU OWN ONE OF THESE PERSONAL HOUSE HEATERS I DONT CARE WHAT ANYONE SAYS REPLACE FACTORY THERMAL PASTE AND PADS I SEE EVERYONE WHO DOES SO DROP UP TO 20c AND THIS IS PROOF!! I have seriously got to say i am mind-blown! The temps and system air intake and discharge are both 25-40% better than when i first got this laptop!
