Is the Corsair CV650 capable of running a RTX 3060ti + Ryzen 5600x?
Risada
I'm getting a new PC and bought the CV650, but I ended up seeing some people not recommending it in similar cases, can this power supply handle the setup? And should I have any worries in the short time, planning to exchange it in a year or so. ?
Not a problem.
Shouldnt be an issue.
Useful threads: PSU Tier List | Motherboard Tier List | Graphics Card Cooling Tier List ❤️
Baby: MPG X570 GAMING PLUS | AMD Ryzen 9 5900x /w PBO | Corsair H150i Pro RGB | ASRock RX 7900 XTX Phantom Gaming OC (3020Mhz & 2650Memory) | Corsair Vengeance RGB PRO 32GB DDR4 (4x8GB) 3600 MHz | Corsair RM1000x |  WD_BLACK SN850 | WD_BLACK SN750 | Samsung EVO 850 | Kingston A400 |  PNY CS900 | Lian Li O11 Dynamic White | Display(s): Samsung Oddesy G7, ASUS TUF GAMING VG27AQZ 27" & MSI G274F
I also drive a volvo as one does being norwegian haha, a volvo v70 d3 from 2016.
Reliability was a key thing and its my second car, working pretty well for its 6 years age xD
19 minutes ago, jonnyGURU said:
Not a problem.
If this guy says it’s fine, it’s fine.
I personally prefer to spend more on an excessive psu just for personal comfort, since a good psu is only a bit more expensive than an average psu. But an average psu is “average” for a reason, it works fine.
Corsairs CV series is pretty decent, lots of people confuse it with the VS series which reminds them of the terrible orange label VS units but the CV’s are pretty ok.
It would probably cry a little but if you can't get something better rn then it's fine.
Tag or quote me so i see your reply
The CV650 shouldn't cry.  We took extra measures to prevent that (Sendust cores, for example).
Huh, good to know. Not that it matters tho, it's probably not very quiet unit otherwise anyway. When we're getting some reviews ? Maybe shake that tree again a little bit ...
I asked Aris to please publish something.  He already did beta testing on it, so he should have all the data he needs.
