Search In
  • More options...
Find results that contain...
Find results in...
PC freezing for half a second with static noise (help)
Every day, my pc freezes for half a second or so with a static noise. Haven't seen if it happens on my monitor speakers but I never use them so I wouldn't know.
This happens when I am playing games and just watching YouTube on chrome.
My pc specs:
Intel i7 7700k 4.20ghz, 4 cores (not overclocked)
GTX 1070 inno3d iChill
Motherboard: Gigabyte Z260XP - SLI - CF
16gm RAM ( was previously 24 but a stick was causing blue screens)
Samsung SSD 860 EVO 550gb (windows running)
Windows 10 pro
Worth noting I'm on a relatively fresh install of windows 10 (after the ram issue I was having)
the static noise has been getting longer and longer every few times it happens, which worries that eventually it will become more common and unstable.
Made sure to scan for any malware or software issues, scanned for faulty memory, drivers, corrupt windows files, updated drivers, searched the web etc
If anyone could help me or guide me in the right direction I would appreciate it.
Maybe one of the other sticks is also dead?
Try underclocking the GPU by like 100mhz, if that doesn't help try the same with CPU.
Quote or tag me so I get notified 🙂 Also mark my post as answer if it answered your question!
GPU MSI Gaming X RX 5500 XT 8gb | CPU Intel Core i5-10400F | Motherboard ASRock B460M Pro4 | Memory HyperX Fury RGB 2x8gb 3200 CL16 | Storage Crucial MX500 500gb (Windows + some games), Crucial BX500 120gb (ZorinOS), Seagate Barracuda Compute 2tb (storage) | PSU Corsair RM650x (2018) | CPU cooler Cooler Master Hyper 212 RGB Black Edition | Monitor AOC C24G2 | Mouse Logitech G703 Hero | Keyboard Drevo Seer Max (Gateron Brown) | Headset Steelseries Arctis 3 (2019) | Mousepad Steelseries QCK
How would I go about seeing how a ram stick is dead?
If you remove 1 of the sticks (assuming it's dual channel) and the freezes are gone that's your issue. Also do the same with the other stick. Disabling XMP could also help, but then it can also be the CPU instead of the RAM.
