will i be able to use a gigabyte oc card with an asus motherboard, or will i have to get another one
Solved by berberries,
Brand of GPU and brand of motherboard has no correlation whatsoever, other than less pain in the ass with RGB software if it is all the same brand. So in short, no you don't need a new motherboard
noidea213 ·
Posted in Graphics Cards1 -
TheNaitsyrk ·
3
12345678 ·
Rummers ·
Posted in New Builds and Planning4 -
a7med ·
Posted in CPUs, Motherboards, and Memory1 -
7
1
moondogkill ·
Posted in Cooling3 -
1
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
